20 Most Recent
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Questions & Answers
My computer does not read my external drive (WD
You don't say which version of Operating system you are using. My thoughts are to first go to "my computer" and see if your drive shows up there. If not, get to disk management and see if it shows up there. The crash possibly could have messed up your external drive, and now it needs to be initialized and/or formatted.
I cannot copy files
I used to get this problem until i updated my USB drivers. Or try a different USB port. I only have USB 1.1 and this device is 2.0. They should be inter-compatible but you know how these things are sometimes. Make sure the temp of the drive is reasonable too, I've not had heat problems with this one but i have with other external drives in the past.
Hope something I've said helps.
My WD25001032-001 is on, but it will not connect to the pc (not showing in Explorer either).
The clicking noise is a mechanical failure caused by the read/write arm making contact with the spinning disk or catching on something it shouldn't.
Check the warranty status at:
WD Support Warranty RMA Services
If the drive is out of warranty, and you have important data on the drive, and you can't afford to send it to a company to retrieve your files and have tried absolutely everything to get get it off, you can try this: Put the drive (and silicon packs in there if available to absorb moisture) in an air-tight ziplock bag. Place it in the freezer wrapped in a towel for a few hours. (Chilling the drive makes the metal inside the drive contract enough for the arm to function properly)
Remove from the freezer and immediately attach to the computer. If detected, transfer files immediately. The drive will heat up quickly and the mechanical failure will return.
My kids deleted a large
yes, there is a way recovering the deleted files or data .
try installing RECUVA , OR install TUNEUP UTILITIES TRIAL version and then right click on the recycle bin and select tuneup undelete .and then connect ur external hard disk to ur pc and select the option in tuneup undelete dialog . and the type the name of the file which was deleted and hit restore button at the bottom and the select al place to restore it and it's all done :-)
Wd2500i032
Google is your friend. Try to go for the follwing link of WD. You can even select the desired OS.http://support.wdc.com/product/install.asp?groupid=101&lang=en
I have the Western Digital
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Lost data
Easy Drive Data recovery would of been my first pick!
