Unfortunately, you won't be able to view the manual on your Mac without installing 3rd-party software.
You'll need to find a CHM viewer for your Mac. I can't guarantee this particular program will open the manual you downloaded from Creative, but there's a good chance it might.
Go
here and scroll down to the xCHM for Mac OS folder. Download and install the latest version of the software. From that point, you can try to open it using the xCHM program.
If that doesn't work, you'll have to try to obtain access to a Windows XP computer and use the following instructions.
For viewing the guide to the Muvo T200 on a Windows XP machine, go to
this page. Under "Getting Started," click on "Quick Start User Guide."
Click on "Download." There will be an "Agree" button. RIGHT-CLICK on that button, so that you can save the file (it is a file with a .CHM extension) to your computer. (Opening it at this point won't work).
The instructions on the site explain how to open the file. Here they are, for your convenience:
...follow these steps to view its contents successfully:
- Save the manual on your computer.
- Right-click the manual and select Properties.
- Select the General tab, click the Unblock button, and then click OK.
The manual should display correctly when you open the file again.
Once I followed those instructions (going to the properties of the downloaded .CHM file and clicking on Unblock then APPLY), I was able to open and read the file in its entirety (meaning the links/chapters within the help file worked properly.) Try it a second time in case the file doesn't show the correct info the first time (it's what I had to do).
Here's the text from the first paragraph of the "How to use this manual" chapter that is beneath "Creative MuVo T200 User's Guide:"
"This document has been designed to provide you with complete product knowledge.
You can resize the document window, print this document, access linked web sites
and get information from specially prepared graphics."
Good Luck!
