I was sewing a thin hem and as I was going to turn the corner the needle pushed the hem inside the feed dogs. I had to pull the fabric out. I got a C4 message and the machine locked up. now it won't sew
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
SOURCE: I have a Singer 6268 electronic machine (25 years
The nylon timing gear may have broken up or the top gear amy have broken up, you need to get into the top and have a lokk and also under the bobbin case area in the bottom of the machine, iof thge gears have broken you can buy the gears quite cheaply and fit them yourself, I do have full instructions to retime the machine.
Ken
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
