I just add new toner and the copeir continue blinking toner light
SOURCE: Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
SOURCE: My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
SOURCE: I have got my Sharp AR 5516 but my computer is
Go to sharp site and download patch for windows 7
SOURCE: H2 problem sharp AR 5516
is that mean, I have going down to simulation by pressing
# interrupt 0 interrupt then machine wil shutdown mode than press 14 then press start.
is that true? because I mess up with my copier cannot print because code H2.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
