Maybe, but if it does it will need to be updated. You can update or install from Adobe. Go here:
Adobe Install Adobe Flash Player
SOURCE: My Dell Inspiron 6000 has no audio. Indicates no
Follow the link below, enter your service tag in the area provided, select the correct operating system, then download and run the audio driver for your system. You may need to reboot after the install.
LINK
SOURCE: I have problems with my Adobe Flash Player. I had
Did you directly download it from the website or use your old copy? It's best to directly download from the website and install. Please uninstall it and again reinstall it after running a registry cleaning. You can directly install it from here.. http://get.adobe.com/flashplayer/ Good luck Thanks for using FixYa.
SOURCE: adobe flash player installation; though the
Try to uninstall the Adobe Flash Player Active X and Plug in and then reinstall it as there could be traces of previous versions in the computer which are interfering and making it difficult for the browsers to properly display videos on your computer. You can do this from the computer user settings and manipulating the "Add/Remove" programs list.
-- Try to use Flash Player 9 is your Flash Player 10 is not working fine. You can simply download it from the Adobe web site.
-- Update the drivers, the link is given below which would ask you to download the file through internet and run it on your computer.
-- The problem behind the Shockwave Flash crash could be your sound drivers. Follow these steps:
1) Open Device Manager
2) Look for the sound-card device
3) Note down the name for that device
4) Just uninstall the it.
5) After uninstalling restart your machine.
6) Your Windows 7 or Windows Vista would automatically download and reinstall the sound driver. You can also do it manually through approaching the sound card company's web site.
-- Fix your Windows Registry which is a highly recommended thing you should do to find a quick and reliable fix for common PC errors and crashes.use registry cleaner reginout
SOURCE: how to install winxp to
A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:
313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program
To perform a clean installation of Windows XP, follow these steps:
Post back if it is not working we will be happy to help you.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
Thank you.
Cheers!!!
SOURCE: I want to download Adobe
Hello, there are usually two versions of adobe flash player: one for internet explorer browser and the other for all other browsers. You just have to download the version for the browser you use. You can use this link to download from the adobe website:
It will automatically detect your browser and choose the correct version for you.
