great question. 1MZ-FE
the V6 has a fuel rail and all rails made
have a plug there (pipe plug) to test it or a mounted
Schrader valve (rated for fuel not tire kind at all.)
if not there we add one. on all cars. or make up and adapter
there are many ways, depends on year.
the plug on rail , the valve.
on newer cars a quick disconnect line , you add matching Tee fitting.
some have test port on the fuel filter is outside tank.
here is 95 rail with no fitting, cant find 2000
the 2002 is non return system (2000 i dont know)
summit racing sells a banjo bolt that is hollow to fit rails.
remove banjo at crossover, put in new bolt and bam, got a port.
Hi Angela Topping, are you working on a roof rack?
