Minn Kota Fortrex 80 Bow-Mount Trolling Motor - 24v-80lb.-52 (Minn Kota) Logo
G
Gavin Richardson Posted on Mar 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Minn Kota Fortrex 80" Shaft 24volt motor. The shaft appears to have a lot of play where it connects to the top of the aluminium bracket at the head. How can I repair this?
How can I strip the half round brackets to get to this area and is this a common problem
Bill Boyd
Level 3:
Top Expert:
  • Minn Kota Master 53,816 Answers
  • Posted on Mar 10, 2016
Bill Boyd
Minn Kota Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950738
Points
172802
What do you consider a lot of play
1/2 inch, 1", .02",040" or what
talk with a service agent for the equipment to get the exact amount of end play permissible or down load a workshop manual for the equipment
How do i release 101 fortrex motor from mounting bracket
There is a pin that goes through the shaft, a small circle clip that holds it in place. Remove the clip and pull out the pin. This may require a hammer and drift as they tend to corrode in the aluminum. don't forget to pull the rope and release the catch.
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
I have to manually turn the prop. to get the Minn Kota electric motor to work. Once it gets going it works fine. What is the cause?
I have an all terrain 70 that would not work intermittently. I disassembled the motor and discovered that the brushes wer hung in the brush housing. The housing is clean and the brushes are in great shape. It appeared that the geometry of the brush spring is just right to make it hang at that prticular position. I freed the spring and could not recreate the problem. Reassembled with new gaskets and seals and all is good.
Why does my 65lbs minn kota maxxum not run quite?
Fishing string on shaft, runing while out of water(will burn up seals so fast), bent shaft, off balance prop, bad rotor in the electric motor. lots of variables. I bought one that was noisy out of the box, vibrated very bad from the get go
4helpful
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
16helpful
How do I remove the composite shaft from the motor housing
I just replaced the shaft (composite) on my Endura 34 today. First, remove the crossbolt that attaches the control head to the top of the shaft. Second, remove the top cover of the control head. Third, make note of the wire connections within the control head (take a picture) and then unplug the red, yellow, white and black wires...no need to unplug the main 6 guage red and black power wires. Fourth, with the wires unplugged, pull the shaft with motor housing attached through the transom mount assembly. Fifth, immobilize the motor housing (gently vice?) and heat the socket in which the shaft screws into motor housing. Do not overheat, only use enough heat to soften factory sealant making unscrewing shaft possible. Sixth, reassemble in reverse order.
Notes: Do not use a pipe wrench as this will crush the composite shaft, either old or new. Apply thread sealant prior to installing new shaft (I used Permatex Thread Sealant/Formagasket). Ensure crossbolt hole on top of shaft aligns with motor housing below.
Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
