20 Most Recent Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Questions & Answers
I have a riptide st 80 24 volt bow mount co-pilot.
Start to look for the charge state of your battery. Measure the voltage on the battery connectors when the motor falls out. If lower than 11v your battery is too weak. Also check all the cables between battery and motor. Check foor loose connection or oxidation.
9/25/2017 4:59:03 PM • Minn Kota... • Answered on Sep 25, 2017
0answers
I need a replacement top for the MinnKota Riptide
These guy will take care of you, http://www.jonestrollingmotor.com/
6/14/2017 2:05:58 AM • Minn Kota... • Answered on Jun 14, 2017
0answers
0answers
How to align the prop and nose (bottom) with the handle (top)
FISH307 com Fishing Tackle Superstore This is a link that will allow you to look at a schematic for you motor. Minn Kota hand control motors have a small nut/bolt thru the motor shift aligning the handle with the lower unit. If yours does not line up your either missino this bolt or a previous owner altered the motor. Hope this helps.
12/14/2014 2:37:38 AM • Minn Kota... • Answered on Dec 14, 2014
Replaced speed switch on my at40 minn Kota but it only runs in high speed
sounds as if you have a mother board problem runs on high only
12/19/2013 12:57:49 PM • Minn Kota... • Answered on Dec 19, 2013
2answers
Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
3/28/2013 4:21:55 PM • Minn Kota... • Answered on Mar 28, 2013
The turn feature on my remote trolling motor will not work
Maybe the pin is sheated on the prop...or something is caught in it..check the prop.
12/31/2012 1:07:45 PM • Minn Kota... • Answered on Dec 31, 2012
0answers
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
Popular Tags
87 questions posted
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
View Most Popular
Minn Kota Boating
  • Minn Kota Boating
Most Popular Question
many amps minn kota 80lb thrust motor
  • Boating
