SOURCE: how do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of
digital photos. You can view photos with or without a computer using
just a memory card,
but it's always a good idea to transfer the photos you'll want to view
frequently to the internal memory of your frame. This is also a handy
way to back up your favorite images.
Transferring Photos from a PC
Copying Photos to Your Frame's Internal Memory
Next, open the folder in which you store your photos ("My Pictures,"
for example). Select the photos you want to transfer to your frame. Drag
them to the drive associated with your digital photo frame---this is
the "Removable Disk" drive you located within the "My Computer" folder.
Every photo you selected will then be copied onto your digital frame.
After the files are copied, disconnect your digital frame properly.
If you don't, your frame's internal memory could be damaged. Look for
the system tray in your desktop's
lower right-hand corner. Left-click the icon that shows a gray box with
a green arrow on top of it. Select "Safely Disconnect Hardware." A
dialog box will appear, asking you to select the device to disconnect.
Select the digital frame and click "OK." When the dialog box appears,
click "Close." You'll see a message in the lower right hand portion of
your desktop telling you it's safe to disconnect your frame.
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
Sim cards are for storing things like network keys and other things so you can connect to a mobile network. I'm sure there's a way but I'd use an SD card because they have more data capacity and are more widely supported by phones and tablets
SOURCE: The camera on my new tablet has stopped working
new tablet still under warranty --take it back for an exchange or refund
