20 Most Recent
Toshiba PA3317U-1ETC - Satellite R10, R15, Portege M200 or M205 Series PC Reserve Pen (PA3317U1ETCPEN) Questions & Answers
How to enable the touch screen on my toshiba
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
10/16/2010 10:42:22 AM •
Toshiba...
Answered
on Oct 16, 2010
My young son leaned on my toshiba portege m200
If an external monitor showed graphics, then there is nothing wrong with your Graphics 'chip'.
{'Chip' is a slang term for IC. Integrated Circuit.
The Integrated Circuit for graphics is a GPU. Graphics Processing Unit. Your laptop uses the Nvidia GeForce G0 FX5200 GPU.
Your laptop like many others, does not have a graphics adapter card. It has Integrated Graphics. Another term is 'OnBoard'.
The graphics chip is on the board.
Motherboard.
There is no graphics adapter card to remove, and replace}
Some areas you may wish to address:
1.The Native Resolution is 1400 X 1050. What does it state in Display Properties?
(Right-click on any empty area of your desktop screen.
Click on Properties at the bottom of the list.
Click on the Settings tab)
2.There are known issues with the CMI display cable. Observe the display cable. Look at the letter/numbers under the barcode. Does it start with CMI?
3.There have been known issues with the connectors on digitizer cable
http://www.irisvista.com/tech/laptops/ToshibaM200/Portege_M200_digitizer_2.htm
(The above is for reference to the digitizer cable identification)
10/3/2009 3:02:04 AM •
Toshiba...
Answered
on Oct 03, 2009
Take apart instructions
This sites a good one. If you can't find what you need, let me know
http://www.laptoprepair101.com/
10/4/2008 5:54:45 PM •
Toshiba...
Answered
on Oct 04, 2008
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
