Let it stand in the on position at least an hour to check it's not going through a self defrost cycle. If the temp display then doesn't change and the compressor doesn't run check you have power to the compressor and condenser fan
This is caused by burnt out glow plugs, when the glow plugs fail it changes the resistance so the glow plug controller/timer doesn't cycle properly, it is the same as when a turn signal bulb burns out.
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Your post doesn`t specify a model number, however on most Bosch dishwashers in order to change from "rinse & hold" to "regular" ( or any cycle ) simply turn the unit "on" and once the machine begins push the regular button twice.
Or the button applicable to the cycle you want.
That should change the display to look like this...
If this doesn`t work, try it for "econo" or any alternative and let me know how it goes.
The lid has a prone that protrudes through a hole in the top of the washer. This prone of finger
makes contact with a lever that is connected to a interlock switch. If this switch is not made,
the unit will not enter its wash cycle. Try bending this lever up a little to make better contact
with the finger.
