20 Most Recent Haier HLP23E Top Load Washer Questions & Answers
Sounds like you have a bad timer.
Haier HLP23E Top... | Answered on Oct 31, 2018
if its an unbalance fault make sure the machine is level and not wobbly,if all good then you may need to fit a new set of suspension roads,P.S alot of machines have this problem on small loads
Haier HLP23E Top... | Answered on Jun 04, 2018
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Haier HLP23E Top... | Answered on Sep 10, 2017
the belt may be broken for the spin moter
Haier HLP23E Top... | Answered on Jan 26, 2017
I would replace the pump impeller first!
Haier HLP23E Top... | Answered on Sep 14, 2015
the water pump on a washing machine is nothing more that a water stirrer as the vanes are straight out
the pump is full all the time and passes water if the hose is laid on the floor. the fact that it is not pumping indicates that it is not getting power at the right time. or the motor of the pump has malfunctioned O new pump) The over flowing machine indicates that the hose to the pressure switch ( what you turn for the water amount ) is blocked or has a hole in it
With both problems combined it may be a faulty control board so have a washer machine mechanic have a look at it.
Haier HLP23E Top... | Answered on May 10, 2015
Hi Lina, accordin to the Haier website, E4 stands for "water inlet problem. Water can not inlet or cannot reach the selected level in a proper time.". Unless the ingoing water pressure is really low, I think you need to service the machine. Anyway, hope this helps!
Haier HLP23E Top... | Answered on Dec 13, 2014
tub rubber is torn or cracked can be replaced but for cost u might buy a new washer
Haier HLP23E Top... | Answered on Dec 01, 2014
most of these machines have the sensor fitted either on the heater or just close to it remember the sensor is not very big and they are quite reliable check the heater hope this helps
Haier HLP23E Top... | Answered on May 11, 2014
You need to level it again. (the knobs on the bottom of it are threaded so you can adjust them to make them level, it can be time consuming, so it is best to start with the one that is shortest.
Haier HLP23E Top... | Answered on Mar 23, 2014
Haier HLP23E Top Load Washer Logo
103 questions posted
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Washing Machines
Most Popular Question
washer only drain when hose ground
  • Washing Machines
