Before this happened tv would loose picture. sound bar would keep working but no picture. I shut off tv wait about ten minutes then turn tv on and it would work for days before it would happen again. now it will not turn on.
SOURCE: blackout problems
It could be the LVDS cable that is connected between the logic main board and the main board, sometimes this cable is too short and comes loose from one of the boards, it could also be a sign that the logic main is going out or the panel itself is shorting out
SOURCE: No picture or sound after replacing lamp
Possible bad color wheel... Pull the lamp out & look inside where the lamp sends the light- does the color wheel look defective? If so,replace it. Or, the lamp ballast may be bad.After that,usually replace complete engine.
SOURCE: Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
SOURCE: My Samsung 50" HLS5086W wide screen tv keeps shutting off....
I have a Samsung DLP 61". The TV continued to turn off with no indications from the panel. I did some tests and determined the TV was not getting enough air circulation due to its poor fan inside. I installed a 110v computer fan on the outside of the vents on the rear of the TV to **** the heat out. Worked great and I have never had a problem since. Need further help or pictures let me know
John
SOURCE: Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
