20 Most Recent
Mitsubishi WD-73734 73" Television Questions & Answers
Have a mitsub. WD-73734 working fine this morning with white and black dots - replaced the chip and now the tv won't turn on, green light blinks raptly then the lamp light starts to blinks red/orange
Somehow--the lamp is not firing. Before you go get another bulb--check ALL of your work, and make SURE no connectors to the ballast have been left off or pinched somehow. It is easy to do this. Also, make sure the lamp door switch is making proper contact with the tab on the lamp door. You have already fixed a real problem with this set--do NOT give up so easily now!! ALso--make sure all fans are running. If ANY do not run--it WILL shut down. ANd make sure the color wheel connector has not come loose or been damaged somehow (this will be between the engine and the lamp area--likely have a "hump " raised in the light tunnel betwen the lamp and the engine--this is where the CW is). Even IF the ballast died (NOT likely at all), you can find one on ebay for under 100---and this set IS WORTH the repair. You will NOT be satisfied with some crappy flat-panel as a replacement.
How do you get your xbox 360 to play, on a 65''
HelloThe Xbox 360 connects to a TV using either - COMPONENT (red blue green for video, red and white for audio - COMPOSITE (yellow for video, red and white for audio) - HDMISo, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360. Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1). Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to. This should make the Xbox work. When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
White spots on my screen
Seems like a dead pixel in the display. The only way to fix it is to buy a new screen which could be more than the TV itself or just buy a new tv.
