Dehumidifiers Logo
T
Todd Gonsior Posted on Feb 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you clean the air filter? - LG Dehumidifiers
Morgan T Bradshaw
Level 2:
Habit-Forming:
New Friend:
  • Expert 86 Answers
  • Posted on Sep 04, 2017
Morgan T Bradshaw
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
86
Questions
0
Helped
63435
Points
469
Here's a link to an article written by a service technician with more than 30 years of experience. It gives details on How to Clean Dehumidifier
1helpful
How do I clean the filter on a GE Sahara 25 dehumidifier?
First remove the bucket. Easily clean the filter w/warm soapy water either under lightly running water or carefully gently clean w/towel. Tap lightly to remove any excess water. Place filter up to air dry which shouldn't take long. After putting filter back in, press. & hold the clean filter reminder button for at least 3 seconds.
Bought the Frigidaire 6000 BTU Window Room Air Conditioner LRA067AT7 6 months ago and it worked fine until last week, It will not turn on although plugged in and the wall outlet is good. Is there an auto...
Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
    5)Or instead of washing, you may vacuum the filter clean.
    Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
    The power supply cord contains a current device that senses damage to the power cord. To test
    your power supply cord do the following:
      1)Plug in your Air Conditioner.
      2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
      3)Press the RESET button. Again you will notice a click as the button engages.
      4)The power supply cord is now supplying electricity to the unit. 4)
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
How can I purchase a replacement air filter for keystone kstad70b?
The filter in your Keystone KSTAD70B is meant to be washed. It is not listed as a replacement part in the owners manual. This is copied from the manual:
3. Clean the air filter
Remove the filter every two weeks based on normal
operating conditions.
Remove the filter from the top of the unit (See.Fig.11a),
or to remove the filter,remove Bucket then pull filter
downwards (See.Fig.11b).
Wash the filter with clean water then dry.
Re-install the filter,replace Bucket. CAUTION:
DO NOT operate the dehumidifier without a filter
because dirt and lint will clog it and reduce
performance.
If you have lost or destroyed the filter, go to Amazon and order the Duck Brand 1285234 Replacement Air Conditioner Foam Filter, 24-Inch by 15-Inch by 1/4-Inch, 1-Pack for 96 cents with free shipping as an add-on item to any order. It is also washable so you will be able to use it like the OEM filter material.
I HAVE THE BHD-301-D COMFORT AIRE DEHUMIDIFIER AND THE LIGHT KEEPS BLINKING AND IT WILL NOT RUN I DO NOT KNOW WERE THE FILTER IS TO SEE IF IT NEEDS CLEAN CAN YOU HELP THANKS
The filter is located behind the front louvers. It can be accessed by removing the water collection bucket and looking up into the bucket holder, just behind the louvers. You should see a plastic pull tab handle, which is the filter frame. If you have never removed the filter for cleaning, it may have a piece of plastic tap, which was used for shipping. you will need to remove the tape and discard it, before pulling straight won the filter frame.
The filter can be cleaned by vacuuming it or if it's really dirty, washing it it in warm water and mild dish washing liquid. Rinse thoroughly and shake off any excess water and dry the filter completely before reinstalling it. Never operate the unit with out the air intake filter in place.
Hope I was able to help you and thanks for choosing FixYa..
1helpful
The dehumidifier freezes up and continues to run so it never melts.
Check the air filter. Freeze ups are often caused by low airflow across the cold coil. A dirty air filter can severely restrict air flow. Replace or wash (if a washable type) the filter and allow the dehumidifier coils to defrost completely. Reinstall the filter and be sure to locate the appliance so that air flow in and out of it is not restricted in any way (not up against a wall, behind a door, curtains, etc.) and restart.
If the unit has been run without an air filter, the cooling coil fins are probably choked with dust and dirt. They should be cleaned with a product designed expressly for this purpose such as:
Evaporator coil cleaner is available from many hardware and "big box home supply stores" such as Lowe's or Home Depot.
Use only as directed, and buy filters! it's much easier to replace filters than cleaning coils.
I hope this helps and good luck! Please rate my reply "4 thumbs up" if it was helpful. Thanks!
2answers
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Blowing air out ,not pulling in
It may seem like no air is being pulled in - but air must be going in if air is being blown out. The air coming has to come from somewhere. It is more likely that the air flow is restricted.
This appliance has a reusable, washable filter. It should be checked regularly and cleaned as needed to allow the free flow of air into the appliance. A dirty filter restricts airflow and reduces efficiency of the appliance. It can also cause frost to clog the fins, too. If this happens, shut off and allow to thaw. Clean the filter, shake off excess water and reinstall. Power up the appliance again and it should work as expected. Do not operate the appliance without a filter installed. If you do, the fins will clog with dirt and are much more difficult to clean than a filter.
I hope this helps and good luck. Please rate my reply - thanks.
Do i just clean the air filter or buy a new one?
clean it - pull out the bucket, look under the front panel lower lip, remove any tape, and pull down the slide-in filter (it fits behind front grill) - just vaccuum and/or rinse and put back in - the tape was just for shipping.
1helpful
Hi Fixya: The Filter on my Danby DDR7009REE Room dehumidifier never seems to accumulate any dust. It is supposed to need to be cleaned every two weeks by vacuuming or soaking, but the filter is always...
How often does the unit run? Does the fan run when the unit is suppose to be running(as the fan pulls the air thru the filter). If every thing operates correctly and the filter is in the right location on the unit then all I can say is that you keep a clean house. Personally I only need to clean the air filter on my dehumidifier about once a summer. I wouldn't be overly concerned if it isn't getting very dirty.
Should I clean or replace the air filter?
You can wash the filter with water, no problem. However, I would recommend replacing the filter every 3 to 4 months depending on how much you use the dehumidifier. The exposure to constant moisture will cause the filter to grow mold over time.
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
