If you go to an AUTOMOTIVE PAINT STORE...
The staff there can better advise you on the
particular application you are attempting...
Very likely you are looking at ALUMINUM ...
(you might want to consider getting it powder coated or electroplated... Painting ALUMINUM is TOUGH).
There are "preparations" required to actually get
through the OXIDATION and allow YOUR
PRIMER PAINT (available in many colors) to stick
to the surface...
Then you can manipulate the surface with YOUR
"sand-paper"...
Anytime you sand through your PRIMER and expose the
ALUMINUM... You should repeat the process... PRIMER AGAIN
and only then apply your surface paint...
READING & understanding the directions on the paints you are using is CRITICAL to success... as is cleanliness ...
A good paint job is all about PREPARATION... but sanding
is quite drastic and should be done as part of the complete SYSTEM...
A tragic number of beginning painters think they can "spot sand" to feather the edges of a "chip"...
From a SURFACE (final finish) all that is accomplished by that is a deeper variation in the surface... that will now need to be leveled out (again).
Two ways to level:
- Primer- SURFACER (fine grit block sand)
- Sand it all down SMOOTH (and re-prime)
Sanding is a CRITICAL skill and can change the shape and LINES of your entire vehicle...
Read & heed the cautions on all paints & primers... Use dust masks, gloves, tac cloths, surface cleaners... eye protection and dust free + well ventilated areas (a lot harder than it sounds )...
With the proper sequencing... really beautiful finishes can be produced (WITHOUT all the gouges and dips caused by shabby sanding techniques)...
Hope this helps
Carnac the Magnificent
