SOURCE: Motorola Bluetooth Hands-Free t305
I have been told by both Motorola and LG that it is a Bluetooth profile compatibility issue. I don't know that there's anything that can be done.
SOURCE: My mobile won't charge from USB port
in your laptop goto device manager. universal serial bus controller. go to appropriate port. Right click- properties - there you will c a power management tab. uncheck Allow the computer to turn off this device to save power. click ok.
SOURCE: connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
SOURCE: How do you connect a vivid bluetooth handsfree spe...
Hope this late reply is still helpful. Press and hold the ON button for at lease 6 seconds until the LCD flashes red and blue alternately, then follow your phone's instructions. The passkey is 000.
SOURCE: iphone 5 charging and connection problems
You need to figure out the amperage of the usb port in the Veracruz, the dealer should have access to that. If the port isn't putting out more than 500ma the iPhone may fail to charge. I recommend a charger atleast 1amp or higher. You either need to connect using bluetooth to the audio system or a hard wired aux cable to the input of the veracruz.
SBT30 Philips NL9206AD-Drachten. Type: SBT30BLE/00
