SOURCE: sears keyless pad
hello - we have a craftsman model 139.53684 and these are the instructions for setting the personal entry code - (you will need two people doing this) To set the code using the Premium control console: 1 Enter a four digit personal ID # of your choice on the keypad then press and hold ENTER. 2 While holding the ENTER button, press and hold the LIGHT button on the premium control console (the premium control console is the main opener button mounted in the garage probably near your door) 3 Continue holding the ENTER and LIGHT buttons while you press the pushbar on the premium control console (now all theses buttons are held) 4 When the motor units lights blink Release buttons - it has learned the new code. If bulbs are not installed you will hear two clicks. To set the code using the 'LEARN' button (you will need a ladder & two people doing this) you used the learn button to set the new remote. 1 press and release the learn button on the motor. The learn indicator light will glow steadily for 30 seconds 2 within 30 seconds enter a four digit personal ID number of your choice ob the keypad then press and hold the ENTER button 3 Release the button when the motor unit lights blink If bulbs are not installed you will hear two clicks. I hope this fixes your problem - please post & let me know - thanks Sam
SOURCE: My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
SOURCE: keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
SOURCE: Have Craftsman model 139.53754 keyless entry pad.
There is always the possibility that it has just quit but you can try programming it. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in your 4 digit code and press enter.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
