20 Most Recent Craftsman Sears 139.30499 AssureLink Compatible Mini Key Chain Garage Questions & Answers
does the remote have reset button and if does then reset the remote and try to program it and if it does not then you probably have to replace it
Craftsman Sears... | Answered on Nov 02, 2014
Control board has thermal issue. Bad solder joint that contracts when cold could be the culprit. Take out board and carefully resolder every ****** connection on board.
Craftsman... | Answered on Apr 03, 2019
Your limits are damaged. Will need to replace the limit switch.
Craftsman... | Answered on Jan 20, 2015
Adam, I don't know how old the GDoor opener is but if it has served you for long time, it's asking for retirement. These days brand new units are cheap and will give you many years of trouble free use.
Craftsman... | Answered on Apr 23, 2014
That is a two-flash code. It means either the wires to the safety sensors have a short in them, or one or both sensors are wired incorrectly at the motor unit. What you describe sounds like there may be a break in the wire, and the door causes the tracks to move just enough to open that break in the sensors. There could be a staple through the wires causing a short (I've done that when using a staple gun), and that could be your problem. Check your sensor wires from the motor down to the sensors themselves, and be sure they have a little bit of wiggle room. If you find a staple or something has cut the wires and caused a short, you can separate the wires a bit, and wrap each side separately with electrical tape.
Craftsman... | Answered on Sep 20, 2013
What exactly is the problem with the remote?
Craftsman... | Answered on Apr 22, 2013
you might have a power failure. can you still use the wall unit?
Craftsman... | Answered on Apr 02, 2013
any home center Lowe's, HD, Cabinet shops ,online
Building... | Answered 2 days ago
CODING LED (red) light flashes when a code is being stored or when a transmitter button is pressed. opener. The opener has to be initialised by the Reset button to make the O/S/C button operable. this button will move the door in the close direction.
https://irp-cdn.multiscreensite.com/86dd1279/files/uploaded/ATAGDO9v3TrioCodeSecuraliftMotor.pdf
Building... | Answered on Feb 12, 2020
Craftsman Sears 139.30499 AssureLink Compatible Mini Key Chain Garage Logo
2 questions posted
Top Craftsman Building Materials Experts
ray gallant
Jay Plesset
Michel Laprise Sr
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Building Materials
Most Popular Question
purchased craftsman assurelink garage
  • Building Materials
