Porter Cable C2002 150 Psi 6 Gal Compressor Logo
Jeri Morrill Posted on Jan 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the motor run but no air pressure develops?
The gauges remain at 0.
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Jan 05, 2016
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
500673
Points
3432
Could be the belt is off or the pistons are not reciprocating
4x4 won;t ingage,2000 chevy tracker
Hi Wayne how's it going ? Here is a Transfer Case Circuit Description ! then I will get into some possibility's of what could be wrong !
There are two main components for the four wheel drive. The powertrain control module (PCM) and the front drive axle actuator pump. The pump is controlled by the PCM. The pump compresses air to engage the front axle. When the transfer case is in four wheel drive (4H or 4L), the four wheel drive switch closes providing a ground signal to the PCM. The PCM actuates the pump which pressurizes the actuator in the front axle. This pressure engages the axle hub which connects the front drive shaft to the axle shafts, allowing the transmission/transfer case to turn the front wheels. The PCM will not operate the pump for more than 10 seconds in order to protect it. The PCM will also provide a path to ground for the 4WD indicator in the instrument cluster. The indicator is provided battery voltage when the ignition switch is in the ON or START position through the IG fuse. With power and ground supplied, the indicator lights.
When the transfer case is in 4L (with auto trans), the four wheel drive low switch sends a ground signal to the PCM. The PCM will not engage the torque converter clutch while this signal is being received.
When the transfer case is returned to the two wheel drive mode, the release valve in the pump opens and releases the pressure in the actuator. Without pressure, the hub disengages.The PCM also releases the ground to the 4WD indicator which causes the indicator to turn off.
Does the four-wheel drive indicator light with 4x4 engaged ? DEFINITION: The 4WD indicator does not illuminate with 4WD engaged. All other engine and transmission functions are normal. Refer to: Electric Motor and Actuator Check in Driveline/Axle-Front Axle (w/diff).
The next step of testing the electric motor an actuator involve a lot of steps an a special tool -
J 43846 Actuator Pressure Gauge
This a factor diagnostic flow chart , I'm not familiar with the in's an out's of this system , the most probable thing's that go wrong with this system. If you want I can send you the diagnostic flow chart !
Tools Required J 43846 Actuator Pressure Gauge
  1. Raise the vehicle. Support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  2. If the vehicle is equipped with an engine skid plate, remove the four bolts that hold the skid plate in place. Remove the front skid plate from the vehicle.
    showgif.do?image=461464
  4. Install theJ 43846 with the air hose connecting between the air pump assembly and the front differential actuator.
  5. Tighten the adjusting knob as far as it stops.
  6. Important: Be careful not to bend any part of the hose.
  7. Turn on the ignition switch and shift transfer lever from 2H to 4H range.
  8. Make sure to check that the motor of the actuator starts running (a running sound can be heard) within 1 second and it stops when the actuator pressure gauge indicates specified pressure. Check for air leakage during the procedure. Pressure specification is: 38.0 kPa (5.40 -- 8.25 psi).
  9. Check that the pressure indicated on the gauge drops as soon as the transfer lever is shifted to the 2H position.
  10. Start the motor of the actuator pump by shifting the transfer lever to the 4H position again. Loosen the adjusting knob to lower the pressure on the gauge. The actuator motor should start to run again and stop in about 4 seconds.
  11. With the adjusting knob of the actuator pressure gauge loosened, shift the transfer shift lever to neutral or the 2H position and then 4L or 4H position. Pump motor should stop in about 10 seconds after the motor starts to run.
    showgif.do?image=461445
  13. Disconnect the air hose (2) from the actuator pump assembly and connect it the front differential air hose inlet. Loosen the adjusting knob.
  14. Connect the air compressor air hose to the actuator pressure gauge.
  15. Compress air into the actuator pressure gauge and turn knob to obtain specified pressure. Specified pressure : 38.0 kPa (5.40 psi)
  16. While both wheels are lifted off the ground, turn one of the front wheels by hand and check the other wheel for the following:
When applying pressure to the actuator pump the other front wheel should turn in the direction opposite to the wheel being turned by hand.
When the actuator pump is not working (by not applying pressure) the other front wheel should remain stationary while the wheel turned by hand is turning.
showgif.do?image=461486
Install the actuator pressure gauge to the actuator pump assembly (1) .
Install a voltmeter and the battery to the pump assembly (1) .
Tighten the adjusting knob as far as it will stop and the air check side opening by a hose as a blind plug.
Check that the actuator assembly motor starts to run (a running sound can be heard) when the battery is connected and when it stops when specified pressure is obtained. Specified pressure is: 38.0- 58.0 kPa (5.40 -- 8.25 psi).
Ensure that the voltmeter is within specifications when the motor is running should be about 0v and when the motor has stopped it should be about 10 -- 14v
good luck !
My air suspension light want go off what can be the problem
  • Air leak
  • Bad sensor
  • Defective pump
  • Bad air bladder
The light remains illuminated while the air pump is given power to provide pressure to the lines. If the light is not going OFF, the system is either not developing enough pressure, or the air pressure sensor has failed and the air compressor motor just keeps running (do you hear it?).
My inground pool filter guage is fairly new and registering 0 even though pool seems to be running fine
if you are sure water is circulating (check to see if water is being sucked into the skimmer suction port or you can open your air relief valve on top of your filter and water squirts out,) then you will know that all works, but if pressure gauge is "0", then replace your pressure gauge.
Motor doesn't run, but light remains steady
There are two possiblilites. One is that the switch is broken (the electrical part of it has failed) and the other is that the motor is broken. Usually is the first based on my experience.
My craftsman 3gal. compressor starts and run but no pressure is building up.it just keeps running and the gauge remains at 0 psi.
Is the petcock down below open or closed? If open, then screw it closed. Also, is the compressor portion connected to the motor working as it should? As the motor reciprocates, it should operate the compressor piston that pumps air pressure into the tank. Maybe something is broken there.
1helpful
2answers
Oil Pressure gauge stuck at maximum, coolant gauge stuck at maximum, speedometer erratic (either not working or working after startup)
The oil pressure gauge on my 2003 Avalanche reads "0" and activates low oil pressure warning. Oil level is OK and engine does not sound like one with with no oil pressure; AKA no knocks or ticking. The mileage is 50,000 on this vehicle any ideas as I with no gauge I am leary of driving it? Please advise!
2helpful
Filter pressure is 0
I'm assuming the pump runs, and the water is circulating from the skimmer back to the pool. Do have the pump running when checking pressure? Second be sure "filter" is selected on multi-port valve. Third, remove gauge with pump off and test gauge with compressed air and be sure gauge is working (don't overpressure gauge depending on gauge scale) If gauge is defective replace. If you still have no pressure on gauge, you might be "bypassing" the filter media (sand) due to a broken pipe from the bottome of the multi-port valve. You sould still see some pressure though as your pump should have some back pressure to the pool.
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
3helpful
OIL PRESSURE LIGHT COMES ON AND PRESSURE GOES TO 0 ON GAUGE
Any time the oil pressure is 0 you take a chance of locking up the motor. The only way to know for sure is to put a pressure gauge in the oil pressure sending unit port on the engine and see what the pressure really is. At that point you will either have the peace of mind in the knowledge that the sending unit is really bad and needs replacement or you can then contact a repair shop and tell them what your testing has revealed. I wouldn't drive or run your truck while the oil pressure is at zero.
Good luck
Top Porter Cable Air Tools & Compressors Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
