Alternator fuse link repaired my way. - YouTube
? 2:10
https://www.youtube.com/watch?v=xgJQXKESDcI
Dec 24, 2013 - Uploaded by Potskie
I had the exact same situation with my ranger. ... I found thefuse links for the charge or alt output but not the one I ..... In line fuse, battery, or alternator? ... Of Key-Off Battery Drain (Parasitic Draw) - Duration: 18:14. by Motor Age.Missing: 2.3
Fusible links and inline fuses? - Ford Truck Enthusiasts Forums
www.ford-trucks.com/forums/885708-fusible-links-and-inline-fuses.html
Sep 17, 2009 - Location: Kuna ID ... The PO had replaced one of the fusible links with an inline 30amp fuse. .... 81-F-150-Explorer is a splendid one to behold .... to charge the battery goes through that link when needed, and/or the battery to the other components when the engine is off. ... 91 ford ranger 2.3 daily driver
1994 Ford Ranger XLT 2.3L man. trans. - Ford Truck ...
Jul 6, 2014
86' Ranger cutting out!!! Fuel ? - Ford Truck Enthusiasts Forums
May 10, 2012
90' 302 fusible link for fuel? - Ford Truck Enthusiasts Forums
Nov 2, 2010
1988 ranger headlights won't work??? help - Ford Truck ...
May 17, 2009
More results from www.ford-trucks.com
Missing: 94
images for Where is the in line fusible link located on a ...
SOURCE: fuseable link
Hi and welcome to FixYa,
In most Japanese brands, the fusible link is the short wire right after the battery that goes to a connector. Often, the battery + terminal has 2 wires; 1 very big that goes to the starter and another the feeds the fusebox. This 2nd wire from the + terminal is the fusible link.
Often fault with the fusible link is a corroded or burned connector/pin.
Good luck and thank you for using FixYa.
SOURCE: How to remove fan clutch on 94 Ranger 4.0?
THERE IS A SPECIAL TOOL THAT CAN BE RENTED OR PURCHASED AT YOUR LOCAL AUTO PARTS STORE. IT CONSISTS OF A LARGE OPEN END WRENCH AND A LONG FORK-LIKE TOOL THAT GRABS THE NUTS ON THE FAN SO THAT THE WRENCH CAN LOOSEN THE LARGE NUT THAT HOLDS THE FAN CLUTCH TO THE FAN. I HOPE THIS HELPS. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. P.S. BE SURE TO LOOK AT THE NEW CLUTCH TO FIND OUT WHICH DIRECTION THE THREADS GO. SOME OF THESE ARE LEFTY TIGHTY, SOME ARE LEFTY LOOSEY. GOOD LUCK
Testimonial: "Very Helpful "
SOURCE: what do the timing belt marks line up on a 94 ford
My apologies for the delayed response. I am going back to answer unanswered questions.
CLICK on the following LINK. It has the Timing Belt & Mark(s) Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my sincerest apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/1994/make/ford/model/ranger/1994_ford_ranger_timing_belt_diagram_marks.htm
