The KX-TGA711 handset can be added to the KX-TGA7160 or KX-TGA7180 system. First, make sure that the answer system is ON. (Use the button on the base or the first few steps below.) For those base units, press the Menu/OK button on the handset. Use the Up/Down arrows to navigate to Answer System. Press the right arrow to enter the sub-menu. If the system is off, turn it on. (Answer On/Answer Off will be displayed on one line. Press the right arrow to access the item.) To record a new greeting, navigate to the line 'Record Greeting' and press the right arrow. Hold the handset about 20 cm away and speak clearly into the microphone. Press Menu/OK to stop recording. Press the Hangup/End to exit and save. A faster access route would be to press 7 and then 6 after accessing the answer system menu. The directions are on page 25 of the manual, which is available from Panasonic and here: http://www.home-phones.co.uk/assets/uploaded/documents/473_7160.pdf . You can do this as a remote operation if you have enabled the feature. Press 7 to record and 9 to stop recording.
I hope this helps.
