First you should really consider upgrading from Windows XP because it is no longer supported and the chances of your computer becoming infected are extremely high.
Pressing the F8 command will only access Windows RE where you can access startup repair safe mode etc.
If the computer is only allowing you to go into safe mode that is a good sign that something is severely wrong with your OS.
While in safe mode you should try and access system restore, but this will only work if 1) you have turned on system restore and 2) your system has a restore point to access.
Have you added any new hardware or programs to the computer? If yes, then the new addition may be the cause of this issue. You can use device manager to rollback any changes or access programs and features to delete any program changes.
Other then that, if none of the above suggestions work I would strongly suggest booting from the disk media to access Windows RE too recovery the computer or just to re-image the computer.
Hope that helps.
I’m happy to help further over the phone at
https://www.6ya.com/expert/james_d4449ffdf318a2c3
