In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
3. Remove retaining ring. If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
4. Remove wheel bearing with suitable tool.
ā¢ Do not remove dust cover unless necessary. ā¢ Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ā¢ Do not remove wheel hub bolt unless necessary. ā¢ Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
Assembly 1. Press in new wheel studs. Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lbā¢ft (147 Nā¢m, 15 kgā¢m) shall not be premissible.
2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
ā¢ Use a new oil seal, and apply grease to seal. ā¢ Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
