GE GTWN4250MWS 27" top-load washer with 3.6 cu. ft. capacity Logo
P
Patty Sullivan Posted on Nov 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer won't spin. Motor goes thru cycle but not spinning
  • Luke Smith
    Luke Smith Nov 15, 2016
    Hi Patty, I'm sorry to hear that your washer isn't spinning. I'll be the first to admit that I'm not an expert in appliance repair, but I imagine many experts would be willing to consult with you for free over the phone at least. Have you tried looking up an appliance repair shop in your area? You could probably just google it and find a few options near you to call and ask.
    http://www.goldlineappliances.com.au/was...
  • Lucy Gibson
    Lucy Gibson Mar 30, 2018
    Patty, I'm sorry that your washer won't spin. My sister is having a similar issue with her washer. The motor is going but not spinning. Hopefully, it's just needing a new part. Finding the right parts might fix the issue, but I'd consult with a professional. http://ea-part.com/
Claude Kayser
Level 3:
Top Expert:
  • GE Master 9,098 Answers
  • Posted on Nov 02, 2015
Claude Kayser
GE Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067928
Points
28436
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Whirlpool direct drive washer won't spin. It goes thru every cycle just fine but won't spin on any cycle. it is not the motor coupling
New washers have DC current motors now.. It is possible that the circuit board is gone out for it to go into spin mode..
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Kenmore washer goes thru all the cycles at the two spin cycles it will pump the water out but it won.t go into the cycle if you grab ahold of the drum and manually give it a start ...
pull the washer out a little awy from the wall,tilt it back so the top rests on the wall,feel around behind the motor,it sounds like the tranny is going and you might find oil around near the back of the motor where the coupling is,also check the coupling,it's behind the motor,it hits the tranny to and when the motor spins it spins the tranny,i've seen the middle of the coupling wear out just catching and if you help it out it will spin but it sounds like the transmission is bad,it's not hard to change it out.send the model number,i can look up your machine,tell you how much a new tranny is and tell you how to change it out,or replace the washer if it's old and put the money into a new washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
No spin
Probably needs new brushes in the motor
Change motor and motor control board
you mean it doesnt spin , but does it goes thru the wash cycle?? if yes , then its not the main motor thats defective,it could be the DRAIN MOTOR PUMP ,COULD BE CLOGGED
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
