If your Titan airless paint sprayer is not getting power, here are some steps you can take to troubleshoot the issue:
Check the Power Source: Make sure that the power outlet you are using is working properly. You can try plugging in a different device to the same outlet to verify if it's providing power. If the outlet is not working, check your circuit breaker or fuse box to see if a breaker has tripped or a fuse has blown.
Note: However, whenever I get stuck with any sprayer, I used alternatives. The best alternative which I prefer always is graco model. You can compare
graco vs titan as well.
2. Power Cord and Plug: Inspect the power cord for any visible damage, cuts, or frayed wires. If thepower cord is damaged, it might be causing a connection issue and preventing power from reaching the paint sprayer. If you find any damage, it's recommended to replace the power cord.
3. Reset Button: Some airless paint sprayers, like other electrical appliances, might have a reset button. Look for a reset button on the sprayer's control panel or near the power cord. Press the reset button if available and see if that restores power.
4. Safety Interlock: Certain airless paint sprayers have safety interlocks that prevent them from turning on if certain parts, such as the gun or nozzle, are not properly assembled. Check if all components are securely and correctly assembled, as an incomplete setup could prevent the sprayer from receiving power.
5. Circuit Breaker or Thermal Overload: Inside the paint sprayer, there might be a circuit breaker or thermal overload protection feature. If the sprayer overheats or encounters an electrical issue, these safety features might trip to protect the equipment. Allow the sprayer to cool down if it's been in use for a while and then try turning it on again.
6. Internal Wiring and Components: If you're comfortable working with electrical components and have the necessary skills, you can open the paint sprayer to inspect the internal wiring and connections. Be cautious while doing this, as you don't want to cause further damage or void any warranties. If you're not experienced, it's best to consult a professional technician.
