Vizio L37 Television Logo
J
Joe Collins Posted on Sep 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio tv sound to speaker outlet dead
No sound when connecting from TV audio out to sound bar. Output connector to head phones works
Jerry Kramer
Level 3:
  • Vizio Master 3,933 Answers
  • Posted on Sep 25, 2015
Jerry Kramer
Vizio Master
Level 3:
Answers
3933
Questions
Helped
882458
Points
12076
Connect the sound bar to the cable box audio out.
I have a LG TV 47LD650 that has picture but no sound out of tv speakers. If I connect an optical cable into the output and use a sound bar, will it still produce sound?
You have to go to setting and change the audio output to TV speakers for the TV speakers to work,, but, if you use a sound bar with optical connection...you have to set it also .. mine works the same way,,
Vizio 42 inch smart tv Model # M420sv
You have to check the audio settings of your tv. There would be n option which allow you to choose the option between internal speakers or external speaker. You have to choose it as external speakers of amplifier.
If you wish to get some more details then check the following link
http://electro-medical.blogspot.com/
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
My TV does not have audio output. will this system still work on my TV?
An audio output may be available if your TV is connected to a TV service provider box. . If you use a box than check to see if there is an audio output available. This will by-pass the TV.
Last resort there is probably a 2.5 mm connection for headsets some where on your TV. You can use a 2.5 mm to White and Red RCA connector cable to connect TV to stereo
This would be a simple stereo connection with out surround..
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Connecting sharp tv to samsung sound bar
don't you mean sound bar to tv?
your tv has an input and output for audio and video,find the audio output and connect the sound bar!
3helpful
2answers
I have an L37HDTV10A that i just replaced the main board...i get picture but no sound...everything looks connected inside...also, what remote do i need?...will a universal work?
Go into ur tv Menu goto OPTION go down to Output Select,press enter make sure selection on (Fixed).This fixed selection will pick for the tv out put to tv speaker.Tv should have sound now on it speakers.Try website like Remotes.com to buy the tv original remote work for the best used for to reajustment setting and setting on the tv Menu.
I was given a 26' GFM LCD TV that has a popping
A sound bar fixed that on my 60" Vizio. But in your case the sound bar may be more valuable than a new TV.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
