WHEN I TURN ON MY TV IT BLINKS THE PICTURE THEN GOES OFF
It may indicate the lamp needs replaced, or that the cooling fans are not turning. When the controller senses too much lamp current, or dimmer than minimum light output, the controller will shut down the lamp to prevent damage. Replacing the lamp fixes that. Over-heating, or fans not rotating will cause the controller to shut OFF the TV. Clean and lubricate the fans with a vacuum and a tiny drop of lubricant on each motor bearing. Also clean and vacuum the air filters. Dust and dirt are the enemies of fans and lamps. Regards.
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
SOURCE: cannot turn tv on
What i did to fix the problem, and no i did not throw it off the porch which was my first idea after i received an estimite. There are 4 capcitors on the d board which a believe is the digital board. Its located to the left of the card tray and its the only board in a steel can cover. They need replacement. I bought mine at radioshack and the repair worked for me. I was later told that the radioshack caps will blow out in a few months but i had already installed them. It worked.You have to desoder the old ones out and resolder the new ones in. It cost me about 2 hours time and 5 dollars at radioshack because i needed to buy solder as well. I will try to find the directions someone sent me and post them, also i will try to find the right (cap) part number as i stated before, the radioshack ones are not going to last. You have to use HIGH HEAT cap do to all the heat the tv puts out.
SOURCE: Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
michtech
SOURCE: sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
SOURCE: mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
