SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
SOURCE: maytag atlantis washer model# mav6451aww
Your first question I need a little more information. What kind of noise is it? Is it a squeek, or a roar, or like rocks in the tub? The second answer is more than likely a timer problem. This part (Maytag # 22004189) costs around $60 to $75 depending on where you live. Run that part number through eBay for special deals sometimes for those parts. Be sure you find out what that noise is first. If you have a transmission or bearing going bad, that could be a costly repair. Let me know what that noise sounds like, and we'll go from there. Jim
SOURCE: groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
SOURCE: washing displaying OE error code
Just resolved same problem...it is the pressure switch aka water level sensor. OE is overflow error. Pressure switch is located under top cover on front right hand side. It is round and has a rubber tube leading down to the drum and a electrical connection to the board. Paid maytag man to diagnose/install cost me about $150
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
