SOURCE: How to send faxes and
Here is a link for all user guides for that printer
If I have helped I'd appreciate the fixya! Thanks
SOURCE: Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
SOURCE: Canon PIXMA MP780 All-In-One InkJet Printer
Press [FAX], then press [Menu].
Use [< ] or [> ] to select <MEMORY REFERENCE>.
Press [OK].
Use [< ] or [> ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>.
▼ If you select <PRINT DOCUMENT>:
1. Press [OK].
2. Use [<] or [> ] to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the Numeric Keys.
If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
3. Press [OK].
4. Press [< ] to print the first page only, or press [> ] to print all pages of the document.
5. To print another document, return to branch-step 2, or to finish printing, go to step 6.
▼ If you select <DELETE DOCUMENT>:
1. Press [OK].
2. Use [< ] or [> ] to select <ALL PRINTED DOCS.> or <1 DOCUMENT>.
– <ALL PRINTED DOCS.>:
Deletes all the printed documents stored in memory.
– <1 DOCUMENT>:
Deletes a single document stored in memory.
3. Go to step 5.
5
Press [OK].
▼ If you selected <ALL PRINTED DOCS.> above:
1. Press [< ].
Press [> ] to cancel deleting, and the machine returns to the standby mode.
▼ If you selected <1 DOCUMENT> above:
1. Use [< ] or [> ] to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the Numeric Keys.
2. Press [OK].
3. Press [< ].
Press [>] to cancel deleting, and the machine returns to the LCD of branch-step 1.
4. To delete another document, return to branch-step 1, or to finish deleting, go to step 6.
6
Press [Stop/Reset].
SOURCE: Trying to receive a fax. Display says
You have to cancel the fax. If its saying that then the paper sent to you was a legal sixe 8.5x14 and needs that type paper to receive the fax. Some faxes have legal trays and A4 but most don't.
