Works on gas and 110v. How can I keep it cold when on the road , 12volt? What position should the switches be in when pulling to stay cold? Thank you
It will take some diagnostics to find the answer so I am placing a link to a diagnostics manual=> Dometic RM2193 Diagnostics Manual You either have a defective 12V heating element, blown fuse or a defective switch. I am here should you have questions, Thanks John T. Appliance 911
SOURCE: RM2652 fridge works on 110 and gas but won't switch between them
Remove the upper control board panel. Use a small screw driver, open the freezer door, under the control panel you will see a slot on each side. Put the screw driver in the slot and push up. That side of the panel will pull out. Do the same on the other side. Turn the control panel over and unplug the circuit board and wait 15 seconds. Plug the board back in and give that a try. If that does not work replace the upper board. To order a board you will need Model, Serial and product # found on the inside of the fridge.
Thanks for using Fixya
Jerry
