20 Most Recent Dometic RM2193 Compact Refrigerator With Ice Box Questions & Answers
wire from board to inside fridge
Dometic RM2193... | Answered on Oct 14, 2017
inside right side slide down
Dometic RM2193... | Answered on Oct 06, 2017
try disconnecting thermistor on back board if cools replace if not bad cooling unit replace
Dometic RM2193... | Answered on Oct 03, 2017
Usually from the Bottom of the refrigerator you should have minimum of 43f or colder than ambient. Should work very close to same on both gas and 110, on Dc it may not cool as good. From your description you may have an issue with ventilation. Cold air needs to flow in through the lower vent and out through the upper, if it cant, cooling efficiency is lost. Adding a fan kit can help on hot days. On gas you may have particles that fell down in the burner. Just take the cover off, take the burner screw out and blow down into burner to clean out. compressor or canned air works fine. If cleaning the burner doesn't improve it enough on gas to match electric you have to make sure your regulator on your rv has enough pressure... the fridges require 11 inches of water column.
Dometic RM2193... | Answered on May 05, 2017
if hot replace cooling unit or thermistor if not hot heater element
Dometic RM2193... | Answered on Jun 18, 2016
disconnect thermistor on back see schematic if ok overnite replace
check to see if 12 volts at unit that runs unit 110 volt for heater element
check for ac power if ok if voltage to board bad board
if other LP d3evices ok check ignitor flame sensor rod
Dometic RM2193... | Answered on Jun 03, 2016
check voltage from convertor maybe blown fuse or loose wires check voltage at back of fridge
Dometic RM2193... | Answered on May 30, 2016
good 2 sided tape clean surface
Dometic RM2193... | Answered on May 27, 2016
high limits overheating if on LP clean lines to ignitor if ac then heater element overheating
It will take some diagnostics to find the answer so I am placing a link to a diagnostics manual=> Dometic RM2193 Diagnostics Manual You either have a defective 12V heating element, blown fuse or a defective switch. I am here should you have questions, Thanks John T. Appliance 911
Dometic RM2193... | Answered on Jun 29, 2015
Dometic RM2193 Compact Refrigerator With Ice Box Logo
Popular Tags
74 questions posted
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Paul G
Paul G
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
will work gas 110 keep cold when road
  • Refrigerators
