Here are 3 links to Sears. The first is a diagram of the drive system of the gt3000. They show 2 belts. One looks to be the drive belt and the other is for the blades. Those are the other links. Hope this helps
To get the most up-to-date data for your craftsman, please search for the belt product on the Lowe's or Home Depot website and check the measurements for the belt product listed on the page.
www.sears.com/craftsman-replacement-belt...42.../p-07133153000..
Sears
Rating: 3.5 - 42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Based on the following info from SearsPartsDirect. Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Possible reasons why the drive belt won't stay are : the belt could be old or worn, you have the wrong size of the
belt.
Also check and verify the pulleys are the right size and properly aligned.
Hi there, On the Craftsman 3000 there is a pin on the back end of the mower that when pulled outward disengages the transmission so it can be moved without it running. Sometimes this pin will stick. It is connected to a lever on the transmission try to push and pull the pin in and out a few times to see if it will free and engage again. You might have to reach under where the lever is connected to the pin rod and try to move it back into position that way. DO NOT REACH IN TO THE TRANSMISSION AREA WITH THE MOWER RUNNING!!! But the pin must be pushed inward for ingagement. This pin will let the mower just sit there like its in nutral and not go anywhere. Try it!!
