I want to make international calls from panasonic kx-t7730 phone that working with pabx.
Http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
or
http://www.ehow.co.uk/how_7159736_program-panasonic-kx-t7730.html
SOURCE: Changing an ordinary phone to a PABX Phone
The KX-T7730 is a proprietary phone that needs to be connected to a Panasonic phone system. It sounds like you took the phone home and are trying to use the special features. These phones are "dumb terminals" everything is performed (and stored) at the control unit.
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
SOURCE: how to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
KX-T7730 is just a headset through which programming can be carried out. For international calling, there are a few setup requirements. By default, you should be able to make international calls. International calling may have been restricted through programming for some or all extensions. Also some clients reques their service providers to bar international calling on their trunks. The procedure depends on the phone system in use. What is the model of your phone system?
