Food Mixers Logo
Carl Buckley Posted on May 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cam and speed dial fell out and I am having trouble putting it back.It is not engaging the on/off switch and when I try to put the cam and speed dial back in place it falls out.Help appreciated i
Model no. is kenwood chef a901
D. E. Hev
Level 3:
Genius:
  • Master 1,187 Answers
  • Posted on May 19, 2015
D.  E.  Hev
Master
Level 3:
Genius:
Answers
1187
Questions
Helped
424897
Points
5819
For what, you need to repost with make and model in a new post
Shifting on my Hobart N-50 mixer. I just pulled the switch/shift cover. yellowish-brownish grease in places, but a few gears looked dry. Tried shifting / no success.
You are in for an adventure. The first step is to find the N-50 Service Manual online and download it.
Trouble shifting speeds is rarely a simple matter of lack of grease.
If your mixer shifted before removing the switch plate, then there is a post that shift lever engages which in not being engaged properly.
On the other hand, if that is not the problem, the transmission case must be removed. Shifting gears involves moving the tumbler yoke assembly. If you are extremely lucky the yoke's spring has become detached and re-attaching it will be all that is needed.
Of course the spring will be in place and you will have to deal with all the grease and investigate the cause.
This is a good time to replace the old grease as well.
Kitchenaid mixer will not run on speeds LOW SPEEDS only runs on speed ten. I've replaced the phase board and that was not the issue. what else could be causing this problem
If it does not start at all until you get to speed 10 then look for a broken wire an any of the wires NOT associated with the phase board. Highly unlikely since you have just been there. Next look at the operation of the switch low down inside the black speed control board. There is a primitive switch there operated by a shaft from your speed control lever. You may find the switch is not activating until it gets right up to speed 10. Have you checked the carbon brushes? The phase board you have just done is normally the culprit for your problem.
Variable speed Cuisinart stand mixer will start and stop when turning the speed dial
I would take a swag at it and guess that the speed control has a variable capacitor consisting of a circular plate and wiper. The plate is a series of contact points that switch the speed control into the circuit. You are missing some of the contact points in the middle of the switching cycle or the wiper is not making contact at that part. You would have to replace the speed control part, but finding the part would not be easy and repairing it was not anticipated due to obsolete thinking on the design of the product.
My machine gradually lost power. Hubby began taking every screw off and trying to get inside before I had a chance to look anything up on the computer :( Turns out it was just the carbon brushes but,...
The switch on the inner side of the black speed control board may have become bent with your repair efforts and the contacts may no longer be touching. One part of the switch contacts is lifted and lowered by the speed link that you put back to its correct position.
Trouble replacing part that has fallen out of the end of my KitchenAir mixer
Sounds like the governor has flown apart, you will need to take that black plate off the back, all the wires off it (take a photo first if you think you will need it) a spring at the bottom and 2 screws at the top. Once you get that off the broken governor will be exposed and you can lever it off with a couple of screwdrivers, don't lose the locating pin through the motor shaft.
Part required is
17830 Governor Assembly
Line up the notch in it with the pin you have in the motor shaft and bang it on with a soft hammer so that the notch engages the pin.
When fitting the back plate back on first engage the speed control lever into where it belongs to operate the switch then put each screw in 8 full turns to start off. I put each one in a couple of turns then the other one until each is 8 turns in. Put the spring back on, put the wires where they belong and fire it up on low speed. Move it up to high then back to speed 1. You want the planetary to turn 13 to 15 revolutions in 15 seconds. I let the planetary knob brush my hand as it rotates while watching the second hand on the clock. Turn the screws in to slow it down and out to speed it up, you should move each screw equally. Once slow speed is set lock up the nuts that stop those 2 screws from turning. Job done!
1helpful
My hobart n50 runs on the same speed in 1 and 2 and will not engage in 3 .. also sounds louder than normal..how do you lube?
Hello Ldl,
I understand that you are having a problem with you 5 quart commercial mixer by hobart. The 1 and 2 are the same speed and you are not getting 3. You also would like to know what oil to use in your machine and how to fill the unit.
To answer you speed question first. The speed is adjusted by the bolt located in the middle of the planetary (the part that turns underneath of the head the attachments hook to). If this bolt is tightened all the way up or to lose it will not allow you to achieve all of the speeds. You will have to adjust this screw many times and turn the machine on to check you speeds. Eventually you will achieve all three speeds.
Before I answer how you lube the machine you need to know what kind of lube to use. The gear box uses a 90 weight gear oil and the planetary uses 140 weight gear oil (grease).
Lubing the gear box with top cover:
1. Remove the top of the gear box (the cover)
2. There is a Round plate with three bolts (do not remove) in this plate there is a disc (looks like a cap seal) use a small screw driver to pry this disc out carefully you will have to put it back once you are done lubing the unit.
Lubing with out a top cover:
1. Remove the switch and gear selector (remember position of gear selector)
2. Fill thru whole in side behind plate removed
Lubing planitary:
1. Remove drip ring
2. Remove the planetary (unscrew bolt in middle)
3. Remove key located in the side of shaft
4. Lube and put back together
Thank you for choosing Fixya.com
Justin
21helpful
Sunbeam Mixmaster 12 speed may need lubrication
Part 1. Oiling the model 12:
Anyone can do this part.
On the top of the motor are four places where oil should be applied.
Starting from the speed finder dial and working forward-
There is a small hole on the top of the motor, just in front of the speed dial. Using a wooden skewer or a match, clean the hole out, and apply two drops of good quality sewing machine oil.
On top of the motor, and near and behind the juicer attaching cone is another hole, sort of key-hole shaped. Clean it out and put in one drop of oil only.
Three drops of oil go into the juicer cone. Let them run down the side of the hole.
Next to the juicer cone is another round hole. You may need to turn the handle as in removing the beaters to uncover it. Clean this hole too, and apply another three drops of oil.
Do not apply more oil than specified. It will get into the works where it shouldn't.
The following proceedures assume some mechanical ability. Read first to assess whether you are competent before starting.
After all these years, the gears in the front of the motor housing probably need fresh grease. This is a fibre based food grade grease that can be obtained from most bearing sellers. (I used a non-food grade grease, but I have to watch that the motor doesn't get too hot, and the grease run down the beaters, which can happen in extreme conditions.)
Prepare to get greasy during this proceedure. Latex gloves are an asset for doing this job.
Remove the cover plate in the centre of the front, and then the central screw from the front and pull away the front housing cover and handle. Don't loose the coil spring inside. It goes over the screw you just undid.
Unclip the return spring on the beater ejector, and remove ejector and spring together, slide the ejector down and off the beater spindles, then up and out of the guides..
There are four screws that retain the gear cover. The lower right hand one also retains a wire. Remove the screws, and gently bend the wire so the cover can be removed. There is a gasket underneath. Take care not to break it, it's brittle.
Once the cover is away, the gears and worm shaft are visible. Using a pop stick or old screw driver, remove the grease around the under side of each gear. A square headed set-screw retains each gear. When you find each screw, remove it completely. Turning the worm shaft will make the gears rotate.
Once both screws are out, pull the beater drive shafts downwards and out of the housing, and lift out the gears.
Using pop sticks, paper towels etc, but NOT solvents, clean out the gear space. Remove all the grease possible. A toothbrush is good for cleaning the worm thread. Use someone elses.
Wash the gears and shafts in petrol, kerosene or similar and dry thoroughly.
Reassembly is the above in reverse order, first filling the gear housing with fresh grease.
Grease each drive shaft lightly before refitting. Note the holes for the set screws in the shafts.
The nylon gear goes on the left, brass under the juicer cone.
Fit the nylon gear first, working the shaft upwards until the locating hole in the shaft can be seen through the screw hole in the gear. Fit and tighten the set screw.
Align the brass gear so both screws face forwards at the same time when engaged with the motor worm, to prevent the beaters clashing. You may have to put the brass gear in and out a few times to get the right teeth engaged with the worm shaft. Then slide the shaft in, once again observing the alignment of holes to ensure the set screw locks the gear securely.
Put everything else back in reverse order. Apply a smear of grease for the beater ejector where it slides, and don't forget to put the wire back under it's screw.
Part 2, speed control.
The jerky operation at low speed is probably due to dirty points in the governer. Addressing this involves disassembling the rear end of the motor.
DON'T pull the motor armature out of the housing without first removing the brushes during this proceedure. There's no need to remove the armature, but if you're curious....
Remove the chrome cap from the centre of the speed finder dial. Remove the lock nut from the thrust control screw under the cap. Remove the dial, catching the washer that goes under the nut.
There is a resistor, usually green, and a capacitor, a small aluminium cannister under the dial. Gently pry the retaining legs away from one end of each and remove them. Note which one goes where so you can put them back correctly. Marking with a felt pen is a good idea.
Now are visible two slotted screws. Remove these screws and pull the governer housing back and away from the motor. Note the pin with a plastic head, and remember to put it back when reassembling the same way around.
Locate and clean the points with a slip of soft wood and metal polish. Clean away the polish thoroughly. Do not use emery paper, it will make the points arc, and speed control will be worse than now.
Put everything back the way it came off.
To reset the governer, leave the locknut on the thrust controling screw loose. Set the speed control to position 1. Whilst pressing the dial home with one hand, screw the thrust screw in or outwards until the motor just starts to run, and lock the screw by tightening the nut. Test the control for full range, and tweak by slightly altering the thrust screw position as required. Getting the speeds just right first go is usually a fluke.
Replace the chrome cap and you're done.
Top Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Food Mixer Expert? Answer questions, earn points and help others
