When electrical stuff doesn't work it is a switch, fuse or fusible link. When you have multiple circuit failures it is likely a bad fusible link. Get out your shop manual for the car and check which fusible link feeds power to these devices; then, test it. If the fusible links all check good, it may be a major connector plug in the electrical harness that is loosing contact. Good luck.
SOURCE: Drivers door power window control stopped
Since it is only happening on the drivers side door to multiple switches and lights on that door only, I think the problem is the wiring harness as it enters the drivers door by the door hinges.
SOURCE: remote fob and power lock buttons wont unlock or
Unless the batteries on your key have run flat and need replacement, the key needs reprogramming. Advanced diagnostics at an authorised service centre will sort both issues pretty fast.
SOURCE: Passenger sliding door doesn´t unlock (Power
Sound like you have a dammaged door latch assembly. It is a pain but you have to take the insid door trim panal off to see what you are doing and make sure the latch assy is un locking. Dis connect power door lock motor linkage to make sure motot is not jaming the lock in the lock possition.
Testimonial: "Thank you gives me at least an idea what I´m looking for. Now I can go see and ask in some shops"
SOURCE: 2005 Freestar "door open signal"
Chances are the autolock doesn't work because it "sees" a door open. Check the plunger between the door and the frame of each door to see if the plunger is broken, bent, or otherwise not working.
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------ Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html ------------- power locks, power window
and power mirror not working? -------- driver side power window problem? ----------- Driver side power window wont go up? --------- Power window problem rear door or window will not open ? -------- Power windows not working after car wash? http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html ------------ How to replace power window motor in car?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
---------power locks, power window and power mirror not working?
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
-------------Complete Diagnosis & Testing Power Windows?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
-----------This will help.Thanks.
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Central locking not working?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
