SOURCE: Fill system....water portion (error message)
It means that you need to fill up the system, inside the machine. Push the Water portion button, then it should flow water from the watertube. If you`re having trouble with this, change the water in the tank with luke warm water, this usually solves the problem after a few attempts.
If nothing happens and no water comes out, the solenoid valve is defective and must be changed.
Please dont forget to vote if you liked my answer
thanks
