Load finished fine but did have a slight burn smell
I would unplug it not very safe to use, if it smoke, and where there smoke there a fire.
Since its a washer not a dryer I would say that something got water on a IC board and it about to short out.
Washer Diagnostic Loud Noise Burning Smell GE Hotpoint RCA General...
Smoke or steam?? May have been a problem with the heater staying on ??
Where theres smoke there is not always fire........ check the rubber seal around the tub and basket. Most likely the basket is rubbing the seal somewhere. This is caused by bearings going bad or the spider that holds the tumbler is cracked or broken. Most places are going to tell you to replace the entire tub assembly. If the bearings are not molded in, you can teplace the bearings and spider yourself.
