SOURCE: Dehumidifier -- LG LHD45EL
If everything is clean on the coils and the filter is clean it should work. I would contact LG because they have a 5 year warranty on these dehumidifiers. Make sure that you have your reciept. Usually what they will do is locate a shop near you and it can be serviced there. LG will pay the bill. Or if there is no local shop they will send you a service tag for your old unit and ship you a replacement unit. Contact LG and explain this problem to you. Everything should be covered under warranty still.
Good luck - Tech101
SOURCE: dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
SOURCE: Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
SOURCE: My LG LHD45EL Dehumidifier is showing a ch 01
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
SOURCE: I've had the lg LHD45EL Dehumidifier for about 1.5
Based on the number of issues on this website with the refigeration coils, this LG model is a piece of junk. I have the exact same problem as described by several people on this website. Is there any recourse we can take against LG ?
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
heatman101
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
