That indicates that the phone is not synced with the base station. Try putting it next to the base station and resetting. Here are some links that may help:
Dear
Connect a telephone set to the extension of the fax machine port where it is marked as EXT.
put the document on ADF or platen glass.
press OHD/Spk Key (get the dial tone)
Dial the required fax no.(get the ring back tone-then RX tone(some kind of beep tone)
Press START.
Display shows sending (if not display may shows 1-sending,2-receiving, then press 1. for sending)
Take the hand set of the telephone hear the noise continuous.
If there is no noise, There some problem with hardware, misht be LIU card, main PBA or both. And you need the assistance of a trained service engineer.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
we r using 'xerox fax center7242a' fax machine. In this we r facing aproblem that is no dial tone in hand set. but dial tone camein speaker. hand set and spiral card ok. pls give solution for the above problem.
