Old houses were wired with single strand wire. how do I rewire a 3 way switch?
Hi Warren,
The connections are the same - regardless if knob and tube wiring or NM/BX cable method is used. It's actually easier to follow with individual wires than in cables - here's how it is connected:
1) In all cases, a wire is connected between source power neutral to the light fixture's white wire or the white or silver colored terminal screw.
2) Source hot is applied to the first switch's "shunt" or "common" terminal (brass or dark colored screw).
3) Two wires (called "travelers") should be connected between the first switch's remaining 2 terminals (called "traveler terminals and are white or silver colored screws) directly to the second switch's traveler terminals (again, white or silver colored screws) and it does not matter which traveler wire goes to which traveler terminal.
4) The second switch's "shunt" or "common" terminal (brass or dark colored screw) is connected to the light fixture's black wire or brass or dark colored screw.
I can help u with this but will need to b able to walk u thru it,
Hi Warren Shaw, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
