20 Most Recent Cooper Wiring Devices 1301-7B GROUNDING SINGLE POLE TOGGLE SWITCH Questions & Answers
How do you wire a cooper 1234 box when you have 4
You must verify that you in fact are dealing with a Neutral wire and a Hot wire to power this device correctly. If this was an existing single pole switch it is likely that the white wire was used as a switch leg to a light fixture .
5/1/2017 3:24:31 AM • Cooper Wiring... • Answered on May 01, 2017
0answers
2answers
Replacing old light switch, only use copper wires?
First, aluminum wire is rarely used anymore, in residential. It's pretty costly to rewire the entire house and you would have to bring it up to the latest codes and have inspections . Usually the single pole switch is used to break the circuit on the "Hot" leg only and the neutral is usually straight wired to the load (Bulb). Based on your description, I would think it's the socket. If it was the switch, it would have sparks or something, not the bulb/ socket. You may have "Blown" the connection in the socket. Kill the breaker and check it.
Hope this helps.
4/29/2010 2:16:19 PM • Cooper Wiring... • Answered on Apr 29, 2010
Wiring a light switch up
black goes to the coloured screw.
white goes to the silver screw
green goes to the green ground screw.
3/3/2010 11:54:15 PM • Cooper Wiring... • Answered on Mar 03, 2010
2answers
Wiring diagrams schematic (boilers)
call me alan 0776 7494009 have books on c, s,y plans
1/17/2010 11:23:53 AM • Cooper Wiring... • Answered on Jan 17, 2010
I have a live 2-wire line that used to be
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
10/18/2009 1:50:06 AM • Cooper Wiring... • Answered on Oct 18, 2009
I need to replace a combination switch for a garbage disposal.
If you don't know what you're doing, it's better to let an electrician do the job properly than having damage done to save a few bucks. Having said that, make sure you TURN OFF THE POWER. If you don't know for sure which breaker operates that circuit, turn off the main breaker. If you can find an identical switch at the hardware store, also grab a circuit power indicator and have somebody show you how to use it. Don't skip that step as it may save your life. Never trust the labels on your breaker panel. Unscrew the cover from the switch. Unscrew the screws at the top and bottom off the switch. Pull it out a little and take note of which wires are connected where. A lot of newer switches have quick connector holes where you can just shove the wire in there instead of having to wrap it around the screw. To release the wires from these holes, stick a small screwdriver or object into the slot next to it and pull. If the old switch has quick connector holes and the new one doesn't, put the wires on the screws closest to the holes. The light may be wired internally in the switch and you won't have to worry about it. It may have two terminals and you have to attach jumper wires yourself. The light, unless for some reason required by your province, it not necessary or common, and you can easily replace it with a normal switch. A combo switch like that will probably come with an instruction sheet that will walk you through wiring it up how you want it. If you choose to use a normal light switch, make sure to pick up a cover plate for it for a few cents. Now you'll connect the bare wire to the green terminal, the white wires should connected with wire nuts unless required by a combo switch with a light, and I doubt it then anyway, and the black wires will connect to the two screws probably on the right side, and will probably be labeled black or hot. Remember that home wiring is generally pretty simple. All wires start inside the breaker panel. If your home has grounded wiring, which means each socket on each outlet has three holes instead of two, the power cables will have three wires. If the outlets only have two, each cable will have two, and if that's the case, you should seriously consider having new wiring installed. You'll thank me when you don't die. House wiring runs on alternating current, which means that the electricity runs back and forth on the wires instead of in one direction, changing directions 60 times a second. Think of it as a sink. The black wire, called the hot wire, is like the high pressure fresh water line. It brings in all the energy. The white or netual wire is the drain for the sink. It carries away the power and is less dangerous than the hot wire. The bare wire is the safety ground wire, is like an overflow drain. If the appliance malfunctions the ground wire will carry away the electricity. When the electricity has a path that satisfies it it will rush down the ground wire so fast that the breaker will trip and the power will shut off. The ground wire keeps you from getting shocked if a wire inside the appliance touches a part of the machinery.
9/17/2009 7:54:41 AM • Cooper Wiring... • Answered on Sep 17, 2009
I installed gfi outlet and I have no power!
turn off circuit, test to make sure its off.
remove the old outlet
black and white wires from breaker attach to line
the wires to the rest of the series attach to load
loop wires to attach in clockwise direction
use electrical tape around outside of outlet to protect terminals.
http://www.thecircuitdetective.com/gfi.gif
http://s44.photobucket.com/albums/f25/silverbird1996/?action=view&current=GFCI1.jpg
3/15/2009 10:46:54 PM • Cooper Wiring... • Answered on Mar 15, 2009
0answers
Wiring a single pole dimmer switch
A single pole switch/dimmer will have two black terminal wires. Power in on one and switch leg out on the other.
5/1/2017 3:02:11 AM • Cooper Wiring... • Answered on May 01, 2017
Os306u single pole switch will not turn off
You have to hook up the ground wire or the light will not go off
3/27/2016 1:46:40 AM • Cooper Wiring... • Answered on Mar 27, 2016
Cooper wiring devices 390-6107xx-eg1d wiring diagram
This is the Cooper product #6107; Standard Series Occupancy Sensor, 3-Way, 500W/400W, Incandescent, Halogen, Fluorescent Rapid Start Ballast. Do NOT use to control light fixtures with CFL or LED lamps! Connect this switch by using the diagram for the #6107 Single-Pole or 3-Way (match your existing switch) linked below. https://objects.eanixter.com/PD365967.PDF
12/10/2015 4:54:10 AM • Cooper Wiring... • Answered on Dec 10, 2015
Cooper Wiring Devices 1301-7B GROUNDING SINGLE POLE TOGGLE SWITCH Logo
14 questions posted
Top Cooper Wiring Devices Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Cooper Wiring Devices Electrical Supplies
Most Popular Question
wire cooper 1234 box when 4
  • Electrical Supplies
