SOURCE: paper feed jam
it will give you a break if the tires are not worn out. Look and feel if they are smooth, if they are smooth and shiny then replace otherwise clean with alcohol.
good luck
SOURCE: hp fax 1020 will not feed paper in
About to junk my hp 1020. Has not fed paper for some time. Used to do it one at a time by hand, but now won't at all. Any suggestions?
SOURCE: I have an HP 2140
An ECM error usually means that the connection is so poor that even the Error Correction Mode cannot cope with it.
Perhaps you started corresponding with someone with a poor telephone line, or your own line has become distorted. Distortions may be the fault of the telephone company or there may be interference from some appliance you or your neighbors recently acquired.
It would be good to consult with your phone company first so they check your line quality for you.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
