When your engine is running at say 1200 rpm, the transmission is at zero speed with the clutch depressed. When you engage the clutch the first gear is still at zero speed trying to engage with a 1200 rpm crankshaft. In a normal transmission, they have a "synchronizer" which speeds up the gear to match the speed of the crankshaft so the gears mesh smoothly.
When you turn off your engine, the crankshaft is at zero rpm so it can go into gear with the zero rpm transmission. Bottom line...you have a problem with your synchronizer on your transmission. If you are lucky...a transmission shop could fix it without an overhall. But it needs to be diagnosed because it doesn't sound good.
SOURCE: 2002 nissan altima
On the left hand side by your left knee, there is a fuse box. Sound like for some reason , you blew a radio fuse. Remove cover, find fuse that sais RADIO and check it.
SOURCE: push on clutch and caR WONT GO IN GEAR UNLESS MOTOR OFF
This sounds like the clutch cable has broken. Not that it couldn't be the diaphram on the pressure plate, but the cable is more than likely the problem.
It won't go into gear while running because the clutch isn't being depressed putting the transmission in a position to allow the synchronizers to work.
When you turn it off, you can easily shift into any gear, but trying to start in gear makes the car try to move. You can verify this by putting it into high gear and trying to start it, you'll still move but less due to clutch slippage. If you put it into reverse, it will try to go backwards-so don't do that!
good luck!
Testimonial: "That is so totally Dead ON!!!! Your Awesome.....THANK YOU SO MUCH for reading what I typed!!!...Now to figure out how to get it fixed...lol....Seriously THANK YOU!!"
SOURCE: I changed my car battery, now my 2008 Nissan Altima key fob won't work
There is a special procedure involved in keying your fob to your car once the battery has been changed. You must lock and open the door with your key. Turn the ignition to "on"(not start) then push the fob's open and close button, then shut off ignition. This procedure is done everything the key battery is changed. Hope this can help you!
Motorcycle Diagnostic Scanner
SOURCE: 2002 Nissan Altima 2.5 s transmission won't shift out of 1st gear after being replaced.
sensor plug with white band goes to the outside sensor, they will plug in wrong and cause the same sympyom
