SOURCE: Technics 1210 MK11 - 'Click' in tone arm movement
Your tonearm is damaged at the pivoting screw. Unfortunately, there is no easy way to fix this other than replacing your tonearm. The pivoting screw is a cone shape screw - aka conical screw - and this sits on 4 ball bearings, with a very thin piece of sheet metal which keeps the ball bearings in place. If this thin piece of metal is damaged - more than likely indented - it causes this sort of clicking sound you speak of. You will need to have the tonearm replaced, as this cannot be fixed. Or, shall I say, it will cost you more to try and fix the problem than it will to just replace the tonearm:
FIX = 3-6hrs @ $85/hr
or
REPLACE = 1hr @ $85 + $70 (tonearm)
You do the math.
Technics Tonearm can be purchased here, but this is not an easy replacement, and you could do more damage if you are not sure of what your doing. Professional repair is recommended. You can buy the part, then bring it to the service shop.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
SOURCE: Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
hi fletch83.
this could be the tone arm bearings too tight,damaged or in need of a little oil.
i had a similar problem on my 1210, it kept jumping all the time,ruining my mixes! it turned out it was the bearings too tight.
unscrew the counter weight so that the arm hovers over the platter and move it to the centre with anti-skate on zero.
slowly turn the anti-skate round to three and the arm should move over to the arm rest smoothly,if it stops before the arm rest or isnt smooth theres your problem,loosen the bearing adjuster slightly and try the hover routine again until its as smooth as you can get it. it is possible,if the turntable has been transported without dust covers the bearings or the pin could be slightly damaged from knocks on the top of the tone arm assembly.
let me know how you get on or if you need any more help.
darren
