20 Most Recent
Crosley 0187SST Turntable Questions & Answers
Cr79 tone arm stops too early
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Sounds low and slow
You can contact the Crosley website and they should sort out the problem you have, as the machine is under warranty.
The record plays too fast
I rather suspect that the problem is in the power supply section to the motor. If the motor is a small voltage type (9 to 12 volt) it will eithier have a control on it, or on the power supply board that will do that. But it will probably be something on the PC board that is causing the problem (often an IC). Trace the wires from the motor to the PC board and you might see the cause! If you have a voltmeter check what's going to the motor too! If it says 12 on the motor and it's getting 15! you know it's the supply. Otherwise it's the motor if the volts are low.
Where do I find a replacement belt for cr249
You need to measure the diameter and thickness of the belt in mm. Please make a note of how the belt fits before removing it. You can search for the belt by putting the measurements into Google they don't have to be spot on!
