My windows and locks seem to have moisture, and they are rolling down on their own. i need to take the fuse off to prevent this from happening.. however i don't have fuse number. please help in identifying fuse from owners manuel
SOURCE: My Driver's Side Window Won't Go Down
it could be the motor or the window switch, go ask a stereo shop if the can test your switch or to see if there is power going to the window motor
SOURCE: 2001 saab 9-3 fuel door will not open
May sound a little stupid im just trying to cover all bases but have you made sure the car is unlocked. If the car is locked then the fuel door will be locked.
SOURCE: infinit g35 radio and AC does not work, already replaced the fuse. help
a circuit board behind the radio is to blame.
6disc changer goes out first then bad signals are sent thru circuit board. components that help control radio n AC burn out eventually, causing the problem you have.
in my car (2003 G35 sedan) i heard a popping sound from radio while driving. my 6disc changer had not been working for a while now and i didnt care or know about this problem until it went further damaging. i had an ipod. well after pop, radio n AC buttons n lights stop working. AC turns on full blast and cannot be turned off. radio only controlled from steering wheel.
you have to ship your radio or drive your G35 to a factory car stereo repair shop. they are hard to come by so thats why you usually have to ship the piece out.
SOURCE: need to remove headlight 2003 infinity g35 sedan
yes ballast is on the bottom of the headlight capsule. remove and note 4 torx heads
SOURCE: 2005 Magnum: I lost my owners Manuel can u tell me which number...
the radio fuse is in the REAR POWER DISTRIBUTION CENTER next to the spare tire (under the cover). it is number 36, 20 amp, yellow.
