Copier shoots ou blank paper
SOURCE: PRINTER PRINT BLANK PAPER
Have you tried putting the machine through a cleaning cycle. There should be a maintenence section on the printer and also on yoour computer. Also if you removed the cartridges and left the printheads exposed for any length of time they have dried out and are clogged. Try removing the heads and cleaning them with a damp lent free cloth.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: hp officejet j4580 will not load paper
i hav no idea and that is a stupid quesion.. what you do is call a mechanic and not let somone on the internet give you false information
SOURCE: I have a officejet K8600
I found a workaround- in Excel highlight cells to print and perform set print area before printing.
SOURCE: My HP Diskjet F4180 All-in-One is working right
go on line at www.hp.com you can download the software from there
Testimonial: "? I thougt it came in CD only ? Sometimes the simplest solutions are the hardest to find. Thanks A LOT!!"
SOURCE: HP 920c Deskjet feeds blank paper constantly.
You may need to go to www.partsurfer.hp.com, in the support area they have drivers and updates. There's one for printers not printing from the internet, and other printing problems. When the test prints work ok, the inks are good then the loss is between the computer and the printer.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Does the scanner energize and pass the document to be scanned?
