To solve you oregne light problem you must do this press power bottom for few seconds to make it flashing Orange this means that the machine is now in descaleing mode then do the descaleing product be sure you use dolce gusto descaleing only after you done reset power bottom this should solve the problem.that was a working for descaleing
HI THIS IS BECOUES YOU ARE DUE TO DO DESCALE .DO DESCALE ONLY WHEN YOU PRESS THE POWER BOTTOM FOR 5 SECONDS TO GET THE MACHIEN INTO DESCALING MODE .SEE THAT YOU GET DESCALING FOR DOLCE GUSTO ONLY IN SIDE YOU HAVE AL THE HALPE YOU NEED
Have you used the pin to clean the needle? It is located behind the water container. It may also then need a coffee machine cleaner to be run through it. Don't use cleaners for dishwashers or washing machines, as these don't look after the internal seals so we'll.
I think what you mean to say is flashing ember this is an indication of descaling but please before you do descaling first remove the diffuser plate which is based on the top of the drawer just in case the plate is blocked. to remove the plate simply
