I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
you need to tie up the drain hose under the sink above where it connects to the drain spigot to stop the sink water flowing down into dishwasher instead of the drain. A blockage in the sink drainage can also make the condition worse.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
Your problem is: Dishwater not filling with water when switched on.
Electric on? Good. 9 times out of 10 it's a bad solenoid valve. It's under the d/w behind the kickplate on the left. I don't recomend this repair for the average homeowner. You might look in the Repair Directory for a repairman. If you're up to it, I find removing the d/w from the cabinet facilitates installation.
Feel free contact me again! Please give me a rating here at fixya.com before you sign off Thank you, Harvey your Master Plumber
